Hi all, I’m trying to make this ship hull as a single surface using curve network, but cannot make it work using both U and V directions; it works as one or the other, but is giving me errors whenever they are combined.
I have tried to split the single keel curve in two in the hope that it will read in the U and V calculations but no joy there either.
Also tried the Sweep 2 Rails option, but doesn’t give me the surface I’m looking for…
Thanks Jessesn, yes that is what I’m looking for… when I try to replicate what you are doing, I get the same fail notice as before - hopefully the video I shared is useful
Only able to do the red section using NetworkSrf - did manage to do the rest of the hull using Loft and MatchSrf. Dont want to change the hull curves too much as matching to a similar hull shape. Will need to spend more time figuring out Curve networks when i get a chance - thanks for your patience
