How to create a sharp 90° step (redan) on a single SubD hydroplane hull?
Hi everyone,
I am modeling a single closed SubD hydroplane hull in Rhino 8 based on a reference background bitmap.
I need to create a sharp, functional 90-degree vertical step (redan) on the underside of the hull. However, whenever I transition from Box mode (Tab) to Smooth mode, the bottom surface behind the step creates an unwanted S-curve bulge/smoothing artifact instead of remaining completely flat
I have tried using Crease on the step edges and adding extra edge loops with InsertEdge, but I’m struggling to maintain a clean edge flow and flat bottom while keeping this as a single closed SubD object.
I’ve attached my .3dm file. Could someone please take a look and advise on the correct topology approach to achieve a clean step transition?
Thanks in advance!
Marek
dornier 212.3dm (840.6 KB)
dornier 212_RG.3dm (1.6 MB)
Is it something like this what you’re looking for?
I used the _SubDExpandEdges on your outer edge, than gumball the new edges to follow the redan.
I’ve also added a symmetry to see it fully.
yes . bud now should be continue of top and botom is step to move up. See picture
  1. move yellow edge to position 2 then create face 3 and bottom of hull has to be closed 4. The continuity shape keep.
for hydroplan is importan have a step
Of course.
In this part you have to think like you have 2 different parts.
So I extruded the back, reduced the shape and the added the “junction faces” by Bridge.
To make the flow better I’ve introduced a new local subdivions around the step.
thank you very much . It looks like feasible it . Now I have to study how you did .I am new bee in Subd and it is quit chalenge to me play with it. Do you have some video how it was done or some similar video on YT?
