Hi All,
I was wondering if there was a way to create a sequence for the pattern i am trying to create, rather than doing it manually?
Thank you for any help!
Chris
weave texture.gh (13.7 KB)
Hi All,
Chris
Not exactly what you’re looking for, but hope this help:
P.S. One thing you’d better avoid is placing your geometry far away from the origin point since it messes with the document tolerances.
Similar to the Seghier’s solution, just a little different.
I got a feeling, that you can do this more elegant using relative item(s) component, but im not really good at this…
