I need to create an individual point at measured locations along various curves, so when they are fabricated, the points will line up. Say on one curve I need it 148mm in from the end, Then the same on another curve.
create a point at the end of your curve,
arraycrv
sellect the point
sellect the curve
in dialog box sellect “distance between items” and if your rhino file units are in mm. type “148” if cm. then type "14.8"
click OK
this will create copies of the point in every 148 mm so you will have lots of points. Delete the unnecessary ones.
