I have a mesh in Rhino created by importing a .obj which represents the 3D model of a forest generated with a drone. It has 887,510 triangular polygons. The z-axis represents the elevation. I want to take this 3D model and subtract its Z, over the entire x-y surface, from that of a 3D model of the forest at a later time. The idea is to create a new 3D model that shows the growth in elevation of the forest. By subtracting the 2 models, the common-mode elevation changes due to terrain is eliminated and only the differential-mode elevation change due to forest growth is illustrated. Ideally this new 3D model would be color coded by z (elevation) in order to enable rapid identification of high and low growth regions.
Any suggestions? So far I have managed to clean up the 3D mesh by draping a surface over it to eliminate surfaces hidden below higher surfaces. So now I have a single surface for the model and I can generate this for the two mesh models of the forest. But I am not sure what to do for the next step. Should I just use the grid created by the Drape command and go grid-by-grid to subtract the z of the two surfaces in each grid cell? This would give me a point cloud with the Z at each point showing the growth that is of interest. I found a command, MeshFromPoints, that can create a mesh over the points and then I could use Drape again to get a surface showing the growth result.
Is this the best way to do this?
A portion of the mesh looks like this:
The flat-looking area is ground while the surrounding taller shapes are trees.
Any help will be greatly appreciated. This is an opportunity for you to help support forest management.
Regards,
Terry.
