In Rhino UI, it looks like below. How to create such material using RhinoCommon in Rhino 7? I’d like to assign it to mesh and surface.
I’ll see if I can quickly create a simple example script.
I created a short script that does the job. First the visual candy:
The script code can be found at:
The literate program from which the script was created: https://jesterking.github.io/rhipy/create_doublesided_rendermaterial.html . This explains the workings in more detail.
Thanks @nathanletwory . Your information is awosome!
