How to copy the transformation of one InstanceObject to another one
in Rhino 8 and RhinoCommon I would like to copy and apply the transformation of one Rhino.DocObjects.InstanceObject (instanceObjA) to another one (instanceObjB). Both instance objects consist of multiple mesh objects.
I tried it this way and it has no effect on instanceObjB:
instanceObjB.Geometry.Transform(instanceObjA.InstanceXform);
instanceObjB.CommitChanges();
I also tried to iterate through all instanceObjB.GetSubObjects() and applied instanceObjA.InstanceXform to those objects without success.
I further tried to iterate through all instanceObjB.GetMeshes(Rhino.Geometry.MeshType.Any) and applied instanceObjA.InstanceXform to those objects as well. No success.
How can I apply the transformation of one Rhino.DocObjects.InstanceObject to another one?
Best regards
Timothy
Find the correct transformation from the current Xform to the target Xform, then use the
RhinoDocument.Objects.Transform method.
That method did the trick.
Thanks Riccardo!
