Hello.
I recently started developing a Rhino Plug-In.
I am developing a plugin that outputs multiple selected objects to a glb for each layer.
However, the following code does not output the texture and material to the glb, only the shape.
using ExportGlb.Utilities;
using Rhino;
using Rhino.Commands;
using Rhino.DocObjects;
using System.Collections.Generic;
using System.IO;
namespace ExportGlb
public class ExportGlbCommand : Command
public ExportGlbCommand()
// Rhino only creates one instance of each command class defined in a
// plug-in, so it is safe to store a refence in a static property.
Instance = this;
///<summary>The only instance of this command.</summary>
public static ExportGlbCommand Instance { get; private set; }
///<returns>The command name as it appears on the Rhino command line.</returns>
public override string EnglishName => "ExportArchModelCommand";
RhinoApp.WriteLine("The {0} command is under construction.", EnglishName);
var objs = ObjectSelector.SelectObjects("Please select objects");
var go = objs.Geometry;
var selectedObjects = new List<RhinoObject>();
for (int i = 0; i < go.ObjectCount; i++)
selectedObjects.Add(go.Object(i).Object());
// Group by layer
var layerObjects = new Dictionary<string, List<RhinoObject>>();
foreach (var obj in selectedObjects)
var layerName = doc.Layers[obj.Attributes.LayerIndex].Name;
if (!layerObjects.ContainsKey(layerName))
layerObjects[layerName] = new List<RhinoObject>();
layerObjects[layerName].Add(obj);
// Output by layer
var dir = Path.Combine(System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments), "rhino_plugin_output", "glb_by_layer");
if(!Directory.Exists(dir))
Directory.CreateDirectory(dir);
foreach (var layer in layerObjects)
var tempDoc = RhinoDoc.CreateHeadless(null);
foreach (var obj in layer.Value)
// Copy material
var materialIndex = obj.Attributes.MaterialIndex;
if (materialIndex >= 0)
var material = doc.Materials[materialIndex];
materialIndex = tempDoc.Materials.Add(material);
var attributes = obj.Attributes.Duplicate();
attributes.MaterialSource = ObjectMaterialSource.MaterialFromObject;
attributes.MaterialIndex = materialIndex;
// Copy geometory
tempDoc.Objects.Add(obj.Geometry, attributes);
var savePath = Path.Combine(dir, $"{layer.Key}.glb");
tempDoc.Export(savePath);
tempDoc.Dispose();
return Result.Success;
When I debug it, I can confirm that the material information is being passed from the original RhinoDoc to tempDoc.Materals
Do you know the correct procedure to copy materials and textures to another RhinoDoc?
Notes
Screenshot of Rhino object and output glb.
The output glb file is attached.
default.glb (3.8 KB)
Environment
- Windows11
- Rhino8
- .NET7
