How to convert a file into 100 x 100 control points
can someone please tell me all the steps and what dialogue window I will need to use, thank you
What problem are you trying to solve?
Can you post a sample file please?
One approach might be to Mesh your surface with the density you need, turn the mesh pointa on, select them and run Extract Points.
hi John,
for the igs boot file-when i project curves to make a sandal part then make the part the part’s edges are not smooth-converting file to 100 x 100 control points fixes the problem
Unfortunately, the rendered image hides the surface structure of the file.
Please post the 3dm file.
I’m still not clear on what the problem is.
I understand that making 10k points seems to help.
rounded toe igs boot.igs
ok here it is thankscan the conversion to 100 x 100 points be done in rhino 5?
Hello- use the Rebuild command for this.
i tried using rebuild but cant figure it out , can someone give me the step by step
thanks
Hello - probably best to look at the Help files and the training material.
