zcstkhk
(Zcstkhk)
October 11, 2021, 2:41pm
1
Hi guys,
Now i am trying write code to convert data from NX to Rhino, When i want to trim a brep, what i really need is like this.
But now result is
I want to know which parameter should I change to optimize this?
And one other thing, When i want to create a trimmed cone/cylinder, top of which is a ellipse, like this
But i get a invalid Brep, and i was told that ON_Brep.m_T[1] 2d curve is not inside surface domain.
Your help will be appreciated. Thx.
dale
(Dale Fugier)
October 11, 2021, 3:49pm
2
Hi @zcstkhk ,
With what little you’ve provided, I’m not sure how to assist.
If the goal is import NX file into Rhino, then you might consider these to resouces:
Rhino plug-ins to convert, import and export files
https://cadexchanger.com/rhino/nx-to-rhino/
NX will also write STEP files, which Rhino will import.
– Dale
zcstkhk
(Zcstkhk)
October 12, 2021, 5:34am
3
Here is the rhino file, which contains a brep created by my tool,
And a brep import from STEP file by Rhino, which is correct.
brep_trim_issue.3dm (114.0 KB)
Hope you can give some advice. Thx.
Willem
(Willem Derks)
October 12, 2021, 3:43pm
4
Hi
FWIW:
With my limited knowledge I would suggest the direction of the trim curve should be reversed.
-Willem
dale
(Dale Fugier)
October 13, 2021, 3:10pm
5
Hi @zcstkhk ,
I suggest using Visusl Studio’s debugger to example the differences between the two. Rhino’s List command can also be helpful in determining the differences.
– Dale
