How to connect 2 circle with a path
hello,
i try to connect 2 circle with different diameter with a path. what tool should i use for that. i try pipe and it doesn’t work.
Hello - Sweep1 seems like the best bet, but if you can post your file I’ll take a look.
I try the sweep1 and it seems it doesn’t work. the result i want is to have a tube with a small circle at the top and a large one at the bottom.
Thanx for the help
circle.pdf (47.1 KB)
Hi @papaarch
Either use Pipe on your center curve and then use the option Thick=yes and set the correct dimensions or run Sweep1 two time - one for the inner and one for the outer circles and Booleandifference the two.
HTH, Jakob
Thanx Normand
