How to ! complex double curvature variant Voronoi pattern + attractor point façade script!
Hi all
First of all, ”I know that I am asking for a lot” and thank you in advance for your help.
I am a BEGINNER at grasshopper – I have Only JUST started using it.
This is my building -
My Façade that I want to transform into a Voronoi surface. This skin will be folded/wrapped on my building.
180507_Facade SkinS.3dm (5.0 MB)
-MY THINKING IS-
I have found a tutorial where he the tutor says in it ‘you can add these scripts together to make one complicated façade’ - YouTube
This is what I want to do (need to do) to make the façade much more unique and complicated. I have tried to compose the multiple types of scripts together into one, but I cannot seem to make them (scripts) all work together!!!
ParaformSurface_WRK.gh (1.3 MB)
(contains all the 3 scripts)
First of all START with his Voronoi system
Then add Random Aperture script
Then add the point attractor script on top
But then apply this to a surface. But this does not tell me how to apply it to a surface!
So onwards to another tutorial
//// Then I found a tutorial that can turn the double curvature surface into a voroni skin with a thickness.= great
VERONI SURFACE.gh (22.8 KB)
This is great Nearly perfect But I don’t know how to combine the first script def with his one!!! :frowning:
is it possible to add all these together??? To make what I am trying to achieve.???
Best Dom
Have you questioned as to why it should be a voronoi pattern? Asking because you are a beginner and for some reason every beginner goes to voronoi immediately. What is voronoi doing for the design?
Just help him with what he wants to do Micheal :joy:
:smiley:
https://discourse.mcneel.com/search?q=voronoi
hi michael,
err i do have to do voronoi as my project went that way with my tutors infulence, hence my tutor said go do voroni.
Hi Michael,
oh great thank you for the help i will get on with your pointers.
as what voronoi will do for the design is that i have other. elements in my model that i snot included in the file that is organic looking but closer to softened triangels aesthetic.
Hi Michael
i guess you did not read my post properly. The problem is joining the 3 scripts i have made into one script,(as the tutor in one of the tutorials say it is possible) can you please help with this please.
