The c++ plugin compiled perfectly but it is also giving .rhp
How to get .dll ?
and can I use c++ plugin dll as reference to my c# dotnet plugin?
How can I get .dll compiled. Is it a different process?
Do I need to write a CLI in c++ to use it in c#?
I do not work in c++, so please do not mind if I ask any meaningless question.
Thanks in advance for the help.
You can use P/Invoke from a C# assembly to call a function inside a C++ dll. The nice thing is that you don’t need a .dll file, this can be done directly into the .rhp file!
For example, we have in a C# assembly the following declaration of an extern function (that exists in the C++ plug-in)
[DllImport("MyCPlusPlusPlugIn.rhp")] // refer to the Rhino C++ plugin
public static extern void SetShowLines(bool value);
and inside our C++ plug-in we have the function
extern "C"
__declspec(dllexport) void SetShowLines(bool value)
// gets called from C#, do stuff in C++ here
The extern "C" {...} is necessary to get so-called unmangled function names in the C++ DLL; and the __declspec(dllexport) is needed so that the name of the function is visible to users of the DLL.
Thanks Steve and Menno ! @menno , you Gave me some ideas, which is very helpful to start with.
Problem is, I forgot c++ All the time writing c# dot net, so now struggling badly to get head around with c++ sdk…Codes at front of me from 7 years back. all looks like Chinese language !
But Your advise is very helpful to start with! and this is all I wanted to know for now.
Will catch up soon.
