How to combine two faces into one?
how to combine two faces into one??
I want to create a bridge between two objects. BUT I can’t because it requires an equal number of faces.
You either have to split the one face face or delete a loop of edges on the two face side…
Try _Bridge after you’ve made sure you have equal face count on both sides. Essentially what @martinsiegrist says.
“delete a loop of edges” how ??
Delete the loop which splits the spherical object vertically.
If you want to keep the same subdivision, the next thing to try is subdivide the large object.
