How to combine a .obj-file with a model_texture-file
my 3d-scan software exported a obj file and the texture combined. after the last app-update rhino doesn’t put the texture over my polygon-surface automatically. is it posible to do this in rhino and HOW???
I’m not familiar with a variation of obj that embeds the texture map. There is an mtl file that goes along with the obj though in most cases that can specify the texture name and the UV mapping info. Maybe the mtl file wasn’t transferred with the obj if you moved the obj between machines. If this is all on one machine and it used to work, can you share two obj, mtl and texture map files as well as screenshots of what they should look like in Rhino 5?
