How to close an open polysurface
Hi friends, I would like to ask how to close the open polysurface?
I crease the upper mesh for shoes, first thing first I created the outer layer, and then copy paste, scale it down to create the inner layer. and then I use ‘Blend Surface’ to connect both the outer and inner layer together.
I thought it will become a close polysurface but turns out when I select the object, it still showing me ‘1 open polysurface added to selection’
Any help would be appreciated
Thanks
run _ShowEdges
and then select “Naked Edges” from the menu.
if you click “zoom” view will zoom in on the edge(s) in the CL you can navigate from edge to edge
Hi @dk2079 many thanks for your prompt reply. Problem solved now, thanks for your help bro…
