The internal force diagram has too many values to display clearly. How can I display only key data, or use color?
Hi which version of Karamba are you using? In 1.3.3 you can control this with the Length/Segment[m] slider in Model View
3.6.1: ModelView - Karamba3D 1.3.3
In 2.2, the results should show on each beam element only.
