How to check if a DimStyles exist or not
Hello all
I want add a dimStyle and it work well. If the dim Style name not exist
int dim_style_index = doc.DimStyles.Add(“RH_3_00”);
Rhino.DocObjects.DimensionStyle RH_3_00 = doc.DimStyles[dim_style_index];
RH_3_00.ArrowLength = 15;
RH_3_00.TextHeight = 15;
RH_3_00.ExtensionLineOffset = 0;
RH_3_00.ExtensionLineExtension = 3;
RH_3_00.CommitChanges();
but if i start the plug-in the second time in the same doc it stopped
so I try to check by
ds = doc.DimStyles.Find(name, true);
but now it break if he not exist
do somebody have a idea how to do?
Thanks Robert
Hi Robert,
This block of code seems to work between file sessions:
  string dimstyle_name = "RH_3_00";
  Rhino.DocObjects.DimensionStyle dimstyle = doc.DimStyles.Find(dimstyle_name, true);
  if (null != dimstyle)
    Rhino.RhinoApp.WriteLine(string.Format("Dimstyle \"{0}\" found.", dimstyle_name));
  else
    int dimstyle_index = doc.DimStyles.Add("RH_3_00");
    if (dimstyle_index >= 0)
      dimstyle = doc.DimStyles[dimstyle_index];
        dimstyle.ArrowLength = 15;
        dimstyle.TextHeight = 15;
        dimstyle.ExtensionLineOffset = 0;
        dimstyle.ExtensionLineExtension = 3;
        dimstyle.CommitChanges();
        Rhino.RhinoApp.WriteLine(string.Format("Dimstyle \"{0}\" added.", dimstyle_name));
    else
      Rhino.RhinoApp.WriteLine(string.Format("Dimstyle \"{0}\" not added.", dimstyle_name));
  return Result.Success;
Let me know if you find otherwise.
– Dale
