var ix = Component.Params.IndexOfName("v");
var has_input = Component.Params.Input[ix].SourceCount > 0;
Or if you keep track of the (input) Params index yourself:
var has_input = Component.Params.Input[0].SourceCount > 0;
if (has_input)
Component.Message = "has input" ;
else
Component.Message = "no input" ;
Be aware if Output params because no event is fired when changing them, so your code wouldn’t be updated when removing a wire. On the Inputs it works though. (See the problem with updating Outputs in this post from yesterday)
// Rolf
