I have a 3dm File with several layouts and want to assign indivicual printers to them.
Is there a way to change the Printer of a page view through .Net
Thanks,
Martin
Thanks,
Martin
Hi Martin,
It doesn’t appear so. I’ve added a wish item for this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36157
– Dale
Hi @MartinIC,
not sure if this helps until this feature gets implemented, but you could write your own Print command which queries a pre-assigned user data value from the layout for the desired printer and then use a scripted _Print
Command to set the printer name before each print starts. I have one old script to get the available printer (names) collection using:
System.Drawing.Printing.PrinterSettings.InstalledPrinters
c.
Hi Clement,
thanks - I’ll try that.
-Martin
