I want to parameterically change degree of a curve. I was hoping to find a change degree component but I only see fit and rebuild components under Curve -> Util panel.
And to my surprise googling didn’t show up anything interesting.
I have shape made on lines (degree 1) and I want to get more control points so I can further modify it but I want to maintain the original shape when I switch from degree 1 to 2.
Hi Guys
I found this old one, so the search tool works well! I can give you a reason where it is helpful:
For the surface morph tool you need grade 3 curves - lower degree curves do not follow the surface correctly. So whenever you surface-morph lines and grade-3 curves you need this tool.
