CornCorn
(CoCo)
1
Hi all,
I finish the UVditor work, I know i can cancel or apply by manual method to press the cancel bottom.
But I want to edit a python or script , I try to many script command ( Enter/cancel…)
Finally, i can not to cancel or apply via script or rhinopython.
Is there an onther way let UVditor to cancel via script or rhinopython ?
thanks,
Coco
dale
(Dale Fugier)
2
Hi @CornCorn,
I don’t know of a way of closing the windows programmatically. I’ve logged a wish.
https://mcneel.myjetbrains.com/youtrack/issue/RH-71512
– Dale
dale
(Dale Fugier)
4
Apparently there is an EndUVEditor
command. Try that.
CornCorn
(CoCo)
5
Hi Dale,
After test, I solved this problem. Thank you for your help.
