How to calculates a point on a curve at x value by rhinoscript?
Maybe something like this?
Option Explicit
'Script by Mitch Heynick ©
'Version 4 February, 2015
Call FindIntersectPointsOnCurve()
Sub FindIntersectPointsOnCurve()
Dim crvID, xVal
crvID = Rhino.GetObject("Select curve", 4, True)
If IsNull(crvID) Then Exit Sub
xVal = Rhino.GetReal("Value along x axis to test?", 0.0)
If IsNull(xVal) Then Exit Sub
Dim plane, insec, i, ptStr, msg
plane = Rhino.WorldYZPlane()
plane(0) = Array(xVal, 0, 0)
insec = Rhino.PlaneCurveIntersection(plane, crvID)
If IsArray(insec) Then
msg = ""
For i=0 To Ubound(insec)
If insec(i, 0) = 1 Then
ptStr = Rhino.Pt2Str(insec(i, 1))
msg = msg & "Intersection point found at " & ptStr & vbNewline
Else
msg = msg & "Part of curve parallel to Y axis at " & Cstr(xVal) & vbNewLine
End If
Next
Call Rhino.MessageBox(msg)
Else
Call Rhino.Print("Curve does not go through X=" & Cstr(xVal))
End If
End Sub
Code worked.Thanks.
Of course, this is much more fun to do in Grasshopper…
