Hi Andre - I think it really helps to line up the points - I do not think you’re getting that bit yet:
Hi Pascal, thank you. But how can I move points if i after the blend I get the surface with thousand points?
Ah. Don’t blend the trimmed edges. BlendSrf between untrimmed edges with no ‘Interior shapes’ or Loft and then MatchSrf.
Hi Pascal, its wonderful, thank you, but when I Shrink or Shrink to edge trimmed surface, it cant become truly untrimmed? I cant get 6x6 surface other way as rebuild the complex one, but then I become this messed surface and can`t align it to other surfaces becaus looks like it nonuniform but Makeuniform doesnt hellp and neighbor surfaces (after Shrink to edge) show bad edges
Hi Andre - use
Untrim
UntrimBorder
or
UntrimAll
Also, I would not worry about the point alignment other than getting the edge rows (i.e. un trimmed surface edges) started in the right direction - lined up with each other - the interior points will take care of themselves with MatchSrf, no to ‘closest point’ and yes to ‘match target isocurve direction’
Hi Pascal, thank you! So it`s impossible to get simple surface from blending/lofting trimmed and shrinked surfaces?
So here I aligned points and its pretty decent, but I can`t match more than 3 surfaces. I can match either side fillets or vertical fillet and bottomandriifilletsnew.3dm (899.9 KB)
Hi Andre - one more MatchSrf, for Tangency only to the vertical filet, with no ‘match by closest point’ should pull it in. When it is only slightly off like this, a match for tangency is often enough and avoids moving the third row of points.
