Hi. I’m trying to create surfaces like the one highlighted in the picture. But the curves are from different list. I’ve divided and shattered both the big and little circle. How do I match the list so they can make separated surfaces?
Hi , could you make a single surface then divide it to get the single surface. then use that surface in a polar array. just an idea. —Mark
If the base geometry is a circle then yes I could. But I want this to apply to any base curve that may not be a circle.
Post the script if you need more help.
I figured it out. Thank you:))
