Such situation
There was a whole SubD model.
I removed several faces so that formed two separate pieces
But these two pieces remain interconnected.
_ExtractSrf or _Ungroup no gives result
How to break a model?
Such situation
There’s no simple way right now, as far as I can tell, so here’s another workaround:
Now you have two subD objects.
I don’t know why normal control-c copy doesn’t work with subobjects. It should be an option. ExtractSrf should also have a copy option.
And the delete that you did, in my opinion, should leave you with two separate SubD objects by default.
Thanks
but long a way
Well yeah, it’s nowhere near complete.
Does splitdisjoinedmesh work?
Tou can also extract meshfaces off an object and this will make a new joined mesh of the extracted faces. I presume this works on subd mesh objects too.
Just tried spliddisjoinedmesh and extractmeshfaces and extractmeshpart, none work.
Explode support for SubD objects is filed as RH-51988 for future reference. It is intended to look at creased edge loops to define regions to separate or to make disjoint SubDs separate.
