How to boolean this?
HELP how to?
WHEEL 1.3dm (15.2 MB)
Hello- the long treads that go around the whole tire have extra surfaces that needs to be removed.
I would make displacement (render mesh modifier) rather than real tire tread. Displacement reduces Rhino model file size and it is easy to change.
@pascal What happen in this case? sorry for multiple post for multiple doubts but in this case when I run boolean in the letters the inward surface disappear and the other treads just fail when I tried to boolean
Hello - in the file you posted there are several open objects -
If you Explode then Join these close up and can be used.
ok that works por some treads but I still have problems with the letters
and the last boolen returns me this:
