It was said that, “by default, a new connection will erase existing connections. Hold the SHIFT button while dragging connection wires to define multiple sources.”
However, even though I was not holding the Shift button, the existing connection still remains the same position. That means I need to manually “Ctrl + Drag” disconnect the previous connection every time, which is troublesome. I am using Rhino 6.5 and Grasshopper. Is there any solution to my situation? Thank you very much.
Not that this is likely to influence the behavior that you are describing but the current version is 6.33. There shouldn’t be any good reason to be running an outdated version.
At any rate, please provide a simple file that misbehaves on your system.
