Instead of 1:0.5, how can I create an integer detail scale 2:1 ?
Select the #:1 format option, then click on the Select Detail Object button.
Click on the border of the detail the text is to relate to and you should see an id appear next to the button:
Click OK and return to the Text dialog where you should see the DetailScale, id and format have populated:
Allowing you to place it on the page:
HTH
Jeremy
Weird, I tried that before but couldn’t get it to work.
It works fine now.
Thanks Jeremy
