Please make your .gh example without Plugins. Try to work with the set of components in grasshopper self. (to see what you did, I now have to install plugins first. And do not want to that).
Try to isolate your question using internalise data. Only the curve/breps etcetera what are really needed to work on your question.
Too bad. If I understand the description, this could be relatively simple. But the GH code I can see is exceedingly complex so I won’t touch it anyway.
Bring examples back to the miniumum, it took me more time then I wanted to find the parts you want me to look at. (see the result to see how you can do that. To finish it off, just internalise the components in “Input Group”
I hope I understood well want you need. I made an example using just a part of your input.
Explanation is in the gh file .
Regards, Eef
Hi eef, ive managed to simplify the script (internalize data)
What im trying to achieve is having the shape of the outer and inner line be perpendicular to the line, and applying like a sort of extruded shape? so that i can visualize what it will look like while also having the taper that i was trying to achieve earlier at certain points
after some studying, ive managed to get what you almost got, however, im not getting the smooth curves when the sizes change? instead im getting a kink
There is a group to move and rotate the basic sections you made. You could expand this with movement per curve, Y direction. Same for rotation.
Be precise!! Check when you copy paste components + settings. Now you did several things twice what gives errors (doubles). In grasshopper: “Almost right = WRONG”
NB: FInal: The forum is for giving tips/suggestions to open up new possibilities, so you can study + proceed. Not for “error-checking”. Internalize 2EW.gh (24.9 KB)
