How to align a view with a construction plane?
I am drawing a building whose one wall is not perpendicular to the rest of them.
I would like to align the views to the wall in a way that one is parallel and the second one is perpendicular.
How to do that?
I draw a surface parallel to the wall and set a new construction plane along its longer edge and I saved it as a named cplane.
In the bottom viewport I choose named cplane and set the view to left, but when I draw anything, it works in some other coordination system.
As you can see in the image, the cube is rotated, while it should be perpendicular to the grey surface.
I would be grateful for helping me with this issue. I tried seeting the view to “left” and camera to “cp left” but that didn’t help.
View>Set Camera>Orient Camera to Surface. You can also set the C-Plane to an object in the same sub menu of “View”.
Typing in ‘Plan’ in the command line will orient the view as a Plan View on the current CPlane as well.
Thank you @double.m.designed but thats what I described in the beginning: I can rotate the view but the objects drawn are not in the same coordinate system as the view.
The same happens if I use “plan” as @Japhy (also thank you) suggested. The view is ok, but the object is rotated.
Another strange thing:
In a viewport, I set the construction plane to the named construction plane and I clicked the plane icon to set the vieport to “cplane front”
I noticed however, that the grid is missing and I can’t draw in this viewport.
When I randomly snapped to some existing elements and created another cube, it was properly aligned with the wall an construction plane. So I solved my problem but another one arose: I can’t draw at all.
