Hi there,
I would like to add a material to an object by knowing the material index however I could not find the method. Only method I can use is the match material, but what if the object is being deleted before the I use it.
Hi there,
does this help ?
if not, you may want to post your code and the used programming language…
kind regards -tom
Hi @onrender,
Generally speaking, you’d do something like this:
var sphere = new Sphere(Plane.WorldXY, 5);
var attributes = doc.CreateDefaultAttributes();
attributes.MaterialSource = ObjectMaterialSource.MaterialFromObject;
attributes.MaterialIndex = material_index; // your index...
doc.Objects.AddSphere(sphere, attributes);
doc.Views.Redraw();
– Dale
Thank you for the hint,
I have found some other methods that helped to achive what I wanted.
My first thought was that the Index is enough to pick up material ID but we need Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject as well.
One other question; What is the difference between the two line because I got error (expected attributes (4) get (3). when I used Rhino.DocObjects.Tables.ObjectTable.
attrChange = Rhino.DocObjects.Tables.ObjectTable.ModifyAttributes(objMat, attr, True)
attrChange = scriptcontext.doc.Objects.ModifyAttributes(objMat, attr, True)
Script:
import Rhino
import scriptcontext
import System.Drawing
def ChangeAttr():
obj = rs.GetObject ( message=None, filter=0, preselect=False, select=False, custom_filter=None, subobjects=False)
matIndex = rs.ObjectMaterialIndex (obj)
rs.DeleteObject(obj)
objMat = rs.GetObject ( message=None, filter=0, preselect=False, select=False, custom_filter=None, subobjects=False)
attr = Rhino.DocObjects.ObjectAttributes()
attr.MaterialIndex = matIndex
attr.MaterialSource = Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject
#attrChange = Rhino.DocObjects.Tables.ObjectTable.ModifyAttributes(objMat, attr, True)
scriptcontext.doc.Views.Redraw();
This:
is attempting to perform an operation on a non-existent object table.
This:
is performing an operation on the document’s object table
Hi Dave,
When I use the script it Ungroups the grouped objects? Is this a bug?
def ChangeMaterial(matIndex, ObjectID):
attrChange = scriptcontext.doc.Objects.ModifyAttributes(ObjectID, attr, True)
I created a new topic: Bug in object attributesin RhinoCommon
