For some reasons I need to add some extra points on the specify brep data structure,
even I hope these points could show in the rhino show window, and How to do?
Does anyone help me?
Hi @jerry1,
I would add the points to the Brep as user data. Then I would create a conduit and look for Breps that contain your user data. When found, draw the points.
β Dale
var rc = RhinoGet.GetOneObject("Brep", false, ObjectType.Brep, out var objRef);
if (rc != Result.Success || objRef == null) return rc;
var brep = objRef.Brep();
if (brep == null || !brep.IsValid) return Result.Failure;
rc = RhinoGet.GetPoint("Vertex to add", false, out var location);
if (rc != Result.Success) return rc;
brep.Vertices.Add(location, RhinoMath.UnsetValue);
doc.Objects.Replace(objRef, brep);
doc.Views.Redraw();
return Result.Success;
AddVertex.zip (94.0 KB)
Hi @Mahdiyar,
Add a pointt to Brep.Vertices
is not recommended. The vertex list of a Brep is reserved for Brep components, and it can be easily modified or purged during editing.
The most reliable way is what I described above.
β Dale
Hi Dale, I try to imitate the sample code C# and translate to vb.netβ¦in the following
but error occur in : face.UnderlyingSurface().UserData.Add(ud)
it appear : userdata must be a public class and have a parameterless constructor
and how to solve it ?
Public Class MyCustomData
Inherits Rhino.DocObjects.Custom.UserData
β
Public Property IntegerData As Integer
Public Property StringData As String
β
Public Sub New()
End Sub
β
Public Sub New(ByVal i As Integer, ByVal s As String)
IntegerData = i
StringData = s
End Sub
β
Public Overrides ReadOnly Property Description As String
Get
Return βSome Custom Propertiesβ
End Get
End Property
β
Public Overrides Function ToString() As String
Return String.Format(βinteger={0}, string={1}β, IntegerData, StringData)
End Function
β
Protected Overrides Sub OnDuplicate(ByVal source As Rhino.DocObjects.Custom.UserData)
Dim src As MyCustomData = TryCast(source, MyCustomData)
If src IsNot Nothing Then
IntegerData = src.IntegerData
StringData = src.StringData
End If
End Sub
Public Overrides ReadOnly Property ShouldWrite As Boolean
Get
If IntegerData > 0 AndAlso Not String.IsNullOrEmpty(StringData) Then Return True
Return False
End Get
End Property
Protected Overrides Function Read(ByVal archive As Rhino.FileIO.BinaryArchiveReader) As Boolean
Dim dict As Rhino.Collections.ArchivableDictionary = archive.ReadDictionary()
If dict.ContainsKey("IntegerData") AndAlso dict.ContainsKey("StringData") Then
IntegerData = CInt(dict("IntegerData"))
StringData = TryCast(dict("StringData"), String)
End If
Return True
End Function
Protected Overrides Function Write(ByVal archive As Rhino.FileIO.BinaryArchiveWriter) As Boolean
Dim dict = New Rhino.Collections.ArchivableDictionary(1, "MyCustomData")
dict.[Set]("IntegerData", IntegerData)
dict.[Set]("StringData", StringData)
archive.WriteDictionary(dict)
Return True
End Function
End Class
Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click
Dim flag_1 As Boolean
Select_Entity_and_Give_Group_Name(11, βselect surfaceβ, flag_1)
If flag_1 = False Then
Exit Sub
End If
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Dim bp As Brep
For g = 0 To surf_base_num - 1
If surf_base(g).Object.ToString = βRhino.DocObjects.BrepObjectβ Then
bp = surf_base(g).Brep
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Dim face = surf_base(g).Face()
Dim ud = TryCast(face.UnderlyingSurface().UserData.Find(GetType(MyCustomData)), MyCustomData)
If ud Is Nothing Then
βNo user data found; create one and add it
Dim i As Integer = 0
ud = New MyCustomData(i, βThis is some textβ)
Else
RhinoApp.WriteLine("{0} = {1}", ud.Description, ud)
End If
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
End If
Next
RhinoDoc.ActiveDoc.Views.Redraw()
End Sub
I find my Class MyCustomData has error β¦ and modify as follow, then the result is ok
but when I add β public pt as point3d in MyCustomData class
the point (0,0,0) is still not appear ??
Public pt As Point3d
Get
End Get
Set(value As Integer)
End Set
End Property
Get
End Get
Set(value As String)
End Set
End Property
' Your UserData class must have a public parameterless constructor
Public Sub New()
MyBase.New()
End Sub
MyBase.New()
IntegerData = i
StringData = s
End Sub
Get
Return "Some Custom Properties"
End Get
End Property
Return String.Format("integer={0}, string={1}", IntegerData, StringData)
End Function
End If
End Sub
Get
Return False
End Get
End Property
End If
Return True
End Function
Return True
End Function
End Class
Hi Dale,
I know your method, but when found, draw the points, and are these points independent? or rely on this Brep? I need these points rely on the brep.
