|Error|CS0029|Cannot implicitly convert type ‘void’ to ‘System.EventHandler<Rhino.DocObjects.Tables.InstanceDefinitionTableEventArgs>’
and
|Error|CS7036|There is no argument given that corresponds to the required formal parameter ‘sender’ of ‘WpfPanel.ThingsToDo(object, InstanceDefinitionTableEventArgs)’|
@dale, thanks.
I just help but feel that I made a more systematic mistake here.
This is the Wpf-Panel I used.
As I can see you are using this… protected override LoadReturnCode OnLoad(ref string errorMessage)
Do I maybe have to use an equivalent method for the Wpf-Panel? Because right now I am doing this in the constructor and as I can see this might definitely not be the right place…
@dale
Sorry to come up with further questions quite some time after we solved this issue.
One question:
If I want to do actions on the WPF-panel (e.g. update a control) so far I am not able to do this.
I suppose it must be the sender passing in the panel, right?
But when I debug the sender is null.
