Hi I am new in the rhino script environment.
Trying some code in the RinhoPyton Editor, start reading points from a CSV
and drawing some curves.
I have ReadPointsDef that return a Rhino.Collections.Point3dList()
points = ReadPointsDef(“point.csv”)
Then I add some objects:
interCurve = rs.AddInterpCurve(points,3,4)
rs.ObjectColor(interCurve, [255,0,0])#red
curve= rs.AddCurve(points)
rs.ObjectColor(curve, [0,0,255])#blue
beCurve = Rhino.Geometry.BezierCurve(points)
Rhino.Add(beCurve) ---> this does not Work
Rhino.RhinoDoc.Objects.Add(beCurve) ---> this does not Work
AddInterpCurve and AddCurve work perfect, but I can´t Add a Rhino.Geometry,
How must to proceed ?
If you look in the debugger, is beCurve actually succeeding (you get something)?
If so does scriptcontext.doc.Objects.AddCurve(beCurve) work? (you need to import scriptcontext)
A Rhino.Geometry.BezierCurve is a special type of curve, used primarily for low level calculations. You cannot add one to a Rhino document because the class does not inherit from Rhino.Geometry.Curve. But, you can convert a Rhino.Geometry.BezierCurve to a Rhino.Geometry.NurbsCurve using Rhino.Geometry.BezierCurve.ToNurbsCurve(). You can then add the resulting NURBS curve to a document.
