How to achieve this kinda drawing?
Hello, i know the commands “Shear” and “Isometric” but i dont get it and feal kinda dumb. Please help me to unterstand how to achieve this kinda drawing 3A/3B from a 3D Modell. Thanks!
you are talking about oblique projections, well, that is an often requested but oh so much ignored problem that has no real and not even straight forward fake solution in rhino. in other apps for instance c4d you get different perspectives one of which is called gentlemen which is quite close to this already but due to the nature of the sides being shown in real dimension it appears pretty exaggerated. what you are showing seems more like a cabinet projection which has shortened sides to overcome the unnatural looking display, i am not sure if there are many apps that actually display exactly that so it is not just rhino
the only real option you have to make it look accurate in Rhino is shear as you have pointed out but that deforms the geometry entirely, which maybe is ok when you dont have to work on that file constantly and just need a final representation. if you indeed have to work constantly further on it having to save revert back and engage the new adjustments each time anew to this projection it indeed would become a pain..
after experimenting with these things often one a little dirty but maybe usable alternative would be to use 2point perspective in Rhino that already sets the vertical lines parallel., then set the camera focal length to something really high like 10.000 and rotate the viewport ever so slightly to the sides. you frontal lines horizontal lines will very slightly tilt but it becomes almost imperceivable at this focal length, after that rotate the camera upwards, you might have to keep rotating for a while since changes in this direction are at this focal length very very subtle.
but since this is such an often requested feature maybe it could indeed manage to gain more attention. you can
below you see perspective and two versions of the suggested setting while the 2nd is has the view rotated downwards stronger which means quite a few rolls with the mouse to get there.
