How to achieve quad mesh like thermal field on a sphere with holes?
I mean inverting the sources and sinks in a circle. This is the Milne Thomson circle theorem. By placing opposing sources/sinks at the inverted point, the circle will be an isocurve of the resulting flow:
It’s not clear what you mean ‘paths or lines will be better’
Also, here’s a version of the earlier sphere definition without using RhinoPolyhedra or Weaverbird
openings_sphere2.gh (23.4 KB)
I am just a month with all this stuff about geometry, patterns, relations, block and grasshopper at all and its quite fascinating . Any recommendations for further reading will be appreciated . Btw . what maths courses do i need to better understand all this? I really thank you for the help , ill read more about this
It started fine but at the end after some time because optimization i iguess the mesh disappear . I included tolerance 0.0001
I am amazed how you develped Nautilus . Its quite amazing and complicated work . quite a bunch of examples to study , thanks
Nautilus is a bunch of tools I did when answering questions on grasshopper3d.com forum and now on this forum. I learned a lot.
What can you suggest me to use to make a custom pattern on my sphere with holes ?
Hello
Your question is too general to be answered. I see you ask it on other threads butbwith no detail.
In general with classical approach a sphere with holes can’t be deformed to a square or rectangle so you can’t have uv map so you cant apply panneling tool or others.
Yeah I asked on this thread , Can not mesh pattern without the holes - Grasshopper - McNeel Forum
