Hi all
how to put colour or text after the user chooses an option from the filter and disappear the other colour or text
I will be looking forward to your reply
multi option with filter and put colour or text of opition.gh (19.6 KB) …Hi all
multi option with filter and put colour or text of opition.gh (19.6 KB) …If you use Relay instead of a parameter like Surface or Brep,
then, you can use Item Index to choose color per geo.
thanks … its work
This is a different way to do it. Two Stream Filter components controlled by the same Value List (blue group). Merge is used for both breps and colors so the wire connections are explicit with no chance of getting them out of sequence.
I can imagine a third way using Cull Pattern…
A third way using Cull Pattern:
P.S. By the way, I noticed some redundancy on the left side of the canvas so simplified that:
Those ‘Bifocals’ labels really mess up the canvas and are redundant unless you use icons.
Slow day. Only three sliders are needed to define these four panels. Got rid of those pesky Bifocals too.
wow, thank you so much… I really appreciate your help
