How much different will Grasshopper 2 be compared to Grasshopper 1?
I recall a past post from a McNeel employee stating “Grasshopper 2 is not Grasshopper 1”. They are quite different I gather?
The main reason I’m asking is because I have a bit of free time and want to pump up my skills. I barely use Grasshopper, so if I was going to learn one or the other, it would be GH2. When getting familiar with GH1 - either learning, re-learning (I find myself getting “back” into it a lot) - it tends to be very time intensive.
There is however quite a lot of content for GH1. I’m thinking about finally buying a course I’ve been looking at for ages. And also getting into 1 - 3 books. Will these skills carry over to GH2?
Yes I know I can just D/L WIP, D/L GH2 and plug away… but many of you already have hence why I’m fishing for opinions.
Thanks!!
As Grasshopper was and probably still is part of academic research, its a polluted ecosystem.
I‘m pretty sure when you follow most tutorials, they will not help you to understand the necessities, but rather explain you how to solve fancy , abstract problems. Better tutorials might explain you how Grasshopper works more in detail, but they may miss to explain the actual knowledge involved or give you any real-world problem solving.
With a solid foundation on what actually happens, you can transfer knowledge 1to1 to similar applications.
While visual scripting will allow you to automate without writing code, its actually easier if you have written code before. Most problems are related to programming (data structures, graphs, datatypes and -arithmetics, API usage), on how to transform geometry in euclidean space. Another big portion is knowledge about CAD modeling.
I think what helps is to solve tiny, useful problems in both applications. The diff is the noise to ignore.
Academics are going to love GH2! for computational drafting workflows GH1 is more suited, due to plugin availability and the Model Object workflow.
