How is Text Size Measured?
I did some test printouts of blueprints. One of my concerns was readability.
I had text as 12 inches in Rhino and I printed out the model at 1:96.
I was expecting the text would be 12 * 72 / 96 = 9 pt.
Instead, the printed text looked like 14 pt., Federal Rules of Appellate Procedure, billboard text staring at me from the 5 foot long sheets.
I need text of various sizes so I was wondering how to convert Rhino text size to point size when scaled.
At 1:96, 12" text will be 1/8th of an inch high. In theory, yes, 9 points at 72 points per inch. Point sizes are difficult though, as the text height of the same number of points varies with the typeface - in text documents. However Rhino makes the heights exact to the specified height (inches or mm). Below are texts with 5 different typefaces at 10mm (distance between the red guidelines) You can see that they are pretty exact.
So you folks do not count the descenders in the text height?
That explains the discrepancy.
