How I can use preselected objects in scripts?
How I can make the following code to work with multiple preselected objects instead to ask-me to select an object?
obj = rs.GetObject("Select object")
if obj:
    rs.SetUserText( obj, "Key1", "0" )
    rs.SetUserText( obj, "Key2", "0" )
Best regards.
Hi @Cumberland
Pretty sure there is a smarter way but here you go :
import Rhino
import scriptcontext as sc
# Get all selected objects (preselected in the document)
objects = sc.doc.Objects.GetSelectedObjects(False, False)
# If no objects are selected, you can ask the user to select one (optional)
if not objects:
    obj = Rhino.Input.RhinoGet.GetObject("Select an object", False, Rhino.DocObjects.ObjectType.AnyObject)
    if obj:
        objects = [obj]
if objects:
    for obj in objects:
        obj.Attributes.SetUserString("Key1", "0")
        obj.Attributes.SetUserString("Key2", "0")
        obj.CommitChanges()
else:
    print("No objects selected.")
Hope this sparks some ideas,
Farouk
Thank you. Works good.
Smarter, I don’t know, easier and less code maybe:
obj_ids=rs.SelectObjects("Select some objects", preselect=True)
If objects are preselected, the script will continue with those. If nothing it preselected, you will get the prompt to select some objects.
