How i can split the surface by these curves
split srf.gh (717.0 KB)
Clean the crv.3dm (611.9 KB)
As this looks like a follow up of your other topic:
you should try to keep the curves and surfaces organised from the beginning.
Maybe also give us a wide picture of what you re after.
for this (partial) question is is necessary to find the curves that lay on each surface and sort them again to fit to the surface-tree
I use a quick and dirty check: if each midpoint is on the surface.
To get according lists of curves I use Series (all indices ) - Cull Pattern (remove the ones with distance > 0.001) - List Item to get a list of curves again.
if you kept the curves sorted in a nice tree structure, above effort would not be necessary.
split_srf_02.gh (724.7 KB)
thanks
Is this possible to lay down these surfaces after spiriting for CNC print with minimum space gap between
I tried a lot but the Nest is loading and loading not working
