How i can modify it
I am trying to create an algorithm with a gradual decrease in relief from the center to the edges,I have been working on this for 2 days and absolutely cannot find a solution
relf exp nodes.gh (15.4 KB)
Are you looking for something like this?
Or this?
yes! I need the 1st option, but with the ability to adjust the height and size of each radius, or set the size of a gradual decrease from the center to the edges of the surface, I will attach sketches below
the green zone is the highest, the yellow one is the middle, and the orange one is the calmest
I don’t see those colored trapezoids in your GH file? And the output of your Anemone loop is peculiar:
Looks like you don’t understand the code I referred to in the other threads.
hi!
yep i teach rhino one month, in first day i not understand how work code, but today ill litl bit more can understand it, but still not understand all of it, anyway I have become more knowledgeable about grasshopper thanks to your help, and sorry if i waste ur time :slight_smile:
