How exactly "Simplify" works?
Hi everyone!
I’ve been playing around with greed patterns and notice that i don’t understand something basic about “simplify” option.
Here is example. If I try to just join these breps, they do not join. Only if I simplify the exits. And I don’t understand why! Even more so, why do I need to simplify every brep? But if i just simplify the input on ‘Brep Join’ component, it does not work!
Triangle pattern Question.gh (38.1 KB)
You are simplifying data trees, not breps. There is a case to be made for never using Simplify, if you truly understand data trees.
If you want to merge all the breps select the Flatten option.
Flatten is another option that is highly discouraged unless you understand data trees.
I had obvious gaps in my understanding of data trees. That video is exactly what I was missing. Thanks a lot!
Since its pattern based on grid - “flatten” would cut the branches i need to manipulate the pattern further.
