Beginner question:
Passing the output of Series through a Panel() somehow changes it, and I’d like to understand how.
I don’t understand why the three lists on the rights aren’t all the same. What’s wrong with the middle row?
series_panel_question.gh (9.3 KB)
Hi @Nicholas_Putnam,
More experienced users can answer your question in better detail but from my understanding it has to do with string/text vs. numeric comparison.
when comparing number components you are comparing Floats and working with floating point precision.
if you put these same numbers into a panel or text node you are now comparing the string representation of said number.
so in some cases if your number is actually 0.00000000000000235298 but “reads” as 0 it may not equal a number of 0 that you are comparing against or an integer of 0 for instance.
if however you compare that long decimal number as text against itself it would match as it’s doing a string comparison. (I think?)
Here you can see the comparisons you are making. The middle example is comparing text against a number, the others are text against text.
By casting the text to a number you get the same result as your text to text comparison in this case.
I hope this helps you!
Thanks! This did help me.
How did you make those type labels appear?
@Nicholas_Putnam I first selected the component then used Ctrl+G to group it and then right click on the group and set the name of it:
That’s my personal preference, I use it as a sort of “code comments” method to explain to myself and others what the logic is doing in a certain area and to also type special keywords like “Deprecate” or “Can we speed this up?” so I can find it easy later
Similarly but different there is a plugin called Bifocals that will show the component name above it.
Skip to the 43 second mark
Since you can hover over a component and have the name displayed I find bifocals unnecessary but I know a lot of users who like it
Don’t do that
Text panels are great for examining component outputs but they should be considered temporary, never inline, so they can be deleted without affecting GH results.
