How does one use Curve->Line->Tangent to 2 Curves
Rhino 7.
How do I draw a 2D line between 2 circles and have it tangent to each circle??
Curve->Line->Tangent to 2 Curves ???
pulleys and belt.3dm (129.0 KB)
Solved it in an archaic way
I tried the first method, but after selecting the first circle, then selecting the 2nd circle, no line appeared between them,
so I solved it with many steps as above.
EDIT - the 2 circles were not co planar!!
_boundingbox
will show that the circles are not on the same plane.
_boudingbox for each circle will show that the circles are parallel to World-YZ (right) (dimension in x=0)
so the circles are not coplanar.
fix with _setPt World set x
Uh no, for the record, that doesn’t give you tangents.
You’re right. Works only for same sized circles.
Good catch - Thanks!
Even with same size circles if the circles are not coplanar then the line between them will not be tangent to the circles with one exception. That exception is if the planes of the circles intersect at the tangent line. Your circles are in parallel planes with a 0.00496 offset so they do not intersect.
If the circles are not coplanar, then there is no line tangent to both circles, or am I missing something here?
Imagine two coplanar circles with a tan tan line between them. Rotate one circle about the tan tan line. The circles are no longer coplanar but are both tangential to the line.
Correct with one exception.
That’s the exception I tried to describe above, but not as clearly.
