Hi All
Does anyone know how to keep the output as two seperate streams?
i guess entwire component does what you ask for.
you get one tree with many branches (list is inside the branch).
No, the opposite. Two separate lists that do not combine!
I was too fast. It seems to split it into separate lists as you say.
But my nodes still produce the wrong output when I feed them all at once. It only works if I feed them one at a time.
Hi, as @flokart said, with Entwine should work…
Just to solve your problem, that is not the entwine, plug the entwine to the cull index…The problem is later. Just don’t flst the offset curves and add a “shift paths” or “trim tree” or path mapper (all of them work) after that.
Wonderful. Thank you.
