How Do I Triangle Grid Array My Geometry?
Hello. I am trying to array this row (img1) vertically so that it appears like in img2: I want the bottom vertex to touch the point where two vertices meet below (I really hope that makes sense). I only know how to array uniformly, which stacks up the shape, and I do not want that. To achieve img2, I had to use the move command after arraying horizontally. But ideally, I will be able to array into a grid using sliders.
cycloid_gh.gh (18.3 K
cycloid_gh (1).gh (24.5 KB)
Wow thank you so much. I hope I can be like you some days.
I notice the rows don’t touch each other at all. Is there a way to change that? Meaning, for the vertex to touch the point where two vertices touch below.
Here’s a different approach, modifying a triangular grid.
2026-10-05_triangular-grid-patch.gh (17.9 KB)
Your shape is bended vertically, so naturally if you want the grid to be vertical they will not touch. Either accept them not touching/change grid to be shifted vertically(skewed)/change the shape
