Vectorize it the same way you traced earlier in the thread and project it on surface.
It does sound like you might want to experiment with rendering, you can apply the brick bitmap as a texture to a surface, set up lights and camera and render it.
I see! I am a complete beginner haha. Anyways, Do u know how do I export it as Vector File OR PNG / PDF file so I can use it in Illustrator?
If the brick pattern is an image you can open it in Illustrator. Try drag-and-dropping it into the Illustrator.
I have rhino 7. I’m using a plugin called Vectorize and it says it’s version 6 compatible.
Works very nicely if working from a clear, crisp line drawing. Brings in the entire drawing and puts them in a group.
@david_wendelken did you inverse url / title ? you might want to edit you re post. - klicking your link does not work -
Tom, indeed I did! Thanks. Fixed it.
Printer ordered and you’ll be getting your credit!
