Hi, I am trying to make a architectural plan and i dont know how to make the toilet look better. Below is the model and the plan. I know that I could just trim the lines, but i have too many models resulting in a confusing mess.
Hi @Max_Scott
As always, it’s close to impossible to tell from a screen shot, so post the file. Nonetheless… Select your mesh and run Weld with an angle tolerance of eg. 70° or 80°. If the mesh is good and has no naked edges, that should prevent make2D from “seeing” the patches. If it’s a single mesh, you can run SplitDisjointMesh to Weld the individual objects with different angles.
HTH, Jakob
Thank you veru much, I will give that a go now.
